0 Members and 1 Guest are viewing this topic. Read 13860 times.
Thanks, found it, very useful Folks over at the Planar asylum didn't take to it very much tho'! Two years later, what do you think of the whole sound stage height thing?Also, how did you break them in and is this crucial? There's a good used pair for on 'Gon that were broken in according to the manufacturer's instructions but others have said you have to use a "harder" process,,lots of bass and volume , I think.
Thanks for the info. It figures that the Anthem is an HT amp as I was listening in a store that sells 90% HT gear. I will give them another listen though, I had forgotten my sample CD's so I'll try again.
I am very curious about the Salk HT2's I have read good things but there is really nowhere to audition them here (Philly) and it's a big chunk of change for me to put down without being sure.....
By far the most amazing speaker I heard (out of my budget range though) were FJ Om's, small (3' high) omnidirectional speakers from Germany. Absolutely amazing soundstage and very musical. I have read the Morrison Audio speakers are similar but both lines are out of my budget range unless I can find them used.The search continues......
