Industry Circles
GR Research
Danny Richie
a weird question
a weird question
0 Members and 1 Guest are viewing this topic. Read 1203 times.
corndog71
Some people call me Rob.
a weird question
15 Jun 2009, 04:59 pm »
So I'm almost finished with my subwoofer cabinet and some friends of mine thought it looked cool in it's raw mdf form. Is it possible to just slap a few coats of polyurethane onto raw mdf?
fcraven
Don't mess with this baritone
Re: a weird question
15 Jun 2009, 09:59 pm »
Yep, you sure can, or if you want to get fancy you can apply some wax to it.and leave it...
not going to be that durable... but hey it works.
I apply some wax to my Festool work table (which is MDF) so that "stuff" doesn't stick to it.
Christof
Industry Participant
Reply #2 on:
15 Jun 2009, 10:06 pm »
Yes, but seal it well and stay away from water-borne finishes unless you know what you are doing.
Check these raw mdf panels out.....
bet the price is through the roof but they would make a nice cabinet
Industry Circles
GR Research
Danny Richie
a weird question
