Help! Can't stream Atlanta Blues Society
0 Members and 1 Guest are viewing this topic. Read 1161 times.
mca
« on: 7 Jun 2009, 06:06 pm »
This has been my streaming radio station of choice for a long time. Tried to play it this morning and got the following message: "connect timed out: bad file descriptor". I am using Squeezebox 3 with firmware 123 and Squeezecenter 7.3.2. Anyone have any idea how to fix this?
MerlinWerks
Re: Help! Can't stream Atlanta Blues Society
« Reply #1 on: 8 Jun 2009, 03:42 pm »
Is this the url you use to get there: http://www.absbluescast.org/ ?
If so, I can't connect to them either. It seems they are actually down...
Give this a try in the mean time: http://wduq.org/audio/index.html#hd3stream
This is my main physical radio station, blues Saturday nights 5p - 1a: http://wyep.org
mca
« Reply #2 on: 8 Jun 2009, 07:09 pm »
That was it, wonder what happened  :(
Thanks for the other links, I'll give them a try
