Tube or SS, which is more EMI/RFI prone?
0 Members and 1 Guest are viewing this topic. Read 9121 times.
Re: Tube or SS, which is more EMI/RFI prone?
« Reply #20 on: 21 Sep 2010, 11:48 pm »
I'd bet my life the F-22 doesn't use tubes. This, despite the fact that EMP, heat and cold are still as much of a problem as it was 30 years ago. That being said, I wonder how we've overcome those issues using solid state technology. Knowing that may help to design a solid state amp.
Bob
Hi Bob,
Perfect shielding in the jets. Even at SAC headquarters (inside a mountain)  which has huge springs to protect against the jarring blast of a direct nuclear blast, even a pin hole will allow enough pulse to enter and screw up things. As the distance increases the effects are not so severe though.
Cheers.
Johnny2Bad
« Reply #21 on: 24 Nov 2010, 09:14 am »
Microwave ovens all have a tube in them?  :scratch:
Magnetron tube, to be specific.
Bob in St. Louis
« Reply #22 on: 24 Nov 2010, 05:02 pm »
That tube like something you'd use to create EMI/RFI, than the vacuum tubes we'd typically talk about on this forum.  :lol:
http://www.gallawa.com/microtech/magnetron.html
Bob
Pez
« Reply #23 on: 25 Nov 2010, 05:33 am »
My tube amps have never had any rfi/emi issues at your house. Nuff said.
