Tube Testing Standard
0 Members and 1 Guest are viewing this topic. Read 1361 times.
iGrant
« on: 5 Jun 2009, 08:14 am »
I've started a thread on what I am relearning about tube testing, with my Amplitrex AT-1000 making me rethink things. Input needed and very welcome:
http://grantfidelity.com/forum/viewtopic.php?t=328
Ian
dangerbird
Re: Tube Testing Standard
« Reply #1 on: 5 Jun 2009, 10:52 am »
Very good read.I'm talking to a member of another audio forum that I am a member of,and he said essentially the same thing as you did,regarding tube matching.  :thumb:
iGrant
« Reply #2 on: 5 Jun 2009, 09:23 pm »
glad to hear it, I'll post some more soon, hopefully some other will to.
Ian
Scott F.
« Reply #3 on: 6 Jun 2009, 12:05 am »
Hiya Grant,
The Amplitrex is a nice unit. I noticed it has a 1/4" headphone jack for listening for microphonics. You should be able to solder up a 1/4" jack assembly that will let you clip your meter onto it and you can start to get actual measurements in mV of the noise associated with a given tube.
The trick is knowing a finite reference point where a tube becomes too noisy for given application (pre, phono or gain). This will take some time trying tons of different tubes to come up with that reference point. Once you do, then you'll be able to better rate or match your tubes.
I've got a Tripplett 3423 that I use. I personally find it is better than the Hicock's or TV-7s because it not only tests for noise at 60Hz but also 120Hz. It gives me a truer read on a tube.
Enjoy!
