Remote access SB3 - can cycle power?
0 Members and 1 Guest are viewing this topic. Read 1410 times.
mcgsxr
« on: 4 Jun 2009, 12:57 pm »
I have been using the SB3 with a laptop, or my Blackberry, as the remote for some time now.
I have never noticed if this can be done, but another AC member reached out to me to ask about it - can you turn off the power of the SB3 remotely?
How?
Thanks guys,
Rasta
Re: Remote access SB3 - can cycle power?
« Reply #1 on: 4 Jun 2009, 01:38 pm »
Well, if you're using squeezecenter, there is always the power button in the upper right-hand corner of web page.
guest4954
  • Guest
« Reply #2 on: 4 Jun 2009, 03:35 pm »
I can with both PC and iPhone. MacMini via the webinterface and iPhone with thee iPeng app.
Regards
Michiel
JEaton
« Reply #3 on: 4 Jun 2009, 08:24 pm »
The Squeezebox doesn't have a true power off.  "Off" is only a standby state.  The best you might do is find is a way to reboot the device, but I don't recall that I've ever seen a way to do it.  Possibly with a pluggin.
