Bryston BP26/MPS 2 Preamplifier vs BP-20 or BP-25/MPS-2 Power Supply.
0 Members and 1 Guest are viewing this topic. Read 17298 times.
  • The Demo is Everything!
    • http://www.bryston.com
Hi All,
I have been asked to describe the differences between the old BP-20/BP-25 used with the new MPS-2 power supply and the new BP26/MPS-2 preamplifier.
THE DIFFERENCES ARE:
1. Depending on age of the BP-25 the gain stage transistors were change some years ago.
2.The RCA jacks were changed on the BP-26.
3. The grounding system changed on the BP-26.
4. The MPS-2 separates the low voltage and high voltage sections of the preamp
5. The older BP-PSR power supply on the BP-25 was an A/C design the newer MPS-1 was a D/C supply
6. The MPS-2 is a D/C supply
UPGRADE OPTON:
If you return your BP20/BP25 to the factory and purchase the MPS-2 through an authorized Bryston dealer all of the above changes are implemented. The upgrade also includes:
New C-Series Faceplate
New (3) C-Series Knobs
New Back Panel.
New 6 Pin Din Power Connector
New Top
New (4) feet
Cost is $600.00 US (not including MPS-2) plus shipping both ways.
James
dswalker
Hi James
I read this and you have me worried about something
I have a BP20 circa 1995. It came to me with a BP-PT power suppply which I recently changed to an MPS-1
Is this the correct Power Supply to use with this Pre amp?
Would I benefit from the changes you mention here in the upgrade?
Best Regards
Doug
Hi James
Best Regards
Doug
Hi Doug,
Yes the original BP-PT or the newer MPS-1 can be used with older BP20/25's with no issues.
Are you asking if the new MPS-2 power supply would sound better on your current BP20?
james
dswalker
Hi James
Thanks for the confirmation on the MPS1
Yes I was wondering if the new power supply would make any difference to the old BP20
Doug
Hi James
Doug
Hi Doug,
It's questions like that which really put me on the spot but I'll try.
So much of the answer would depend on the rest of your system.  I really hate things like 'oh ya it blows the older unit away'  because in reality products at our quality level 'evolve' rather than make huge evolutionary 'leaps'. OK I've stalled enough!
The MPS-2 should give you better bass - not necessarily lower just more defined.  Also the soundstage should 'stay put' as the levels are increased and lastly the very top end should be more open and more spacial without any brightness.
james
dswalker
Thanks James.
I think I will try it.
I am running a 4BSST and Linn Ninkas--home made cables
Appreciate your help
Doug
Chicago
Hi All,
UPGRADE OPTON:
New Back Panel.
New Top
New (4) feet
James
James,
Is Bryston still providing this service and is the cost about the same.
Mike
James,
Mike
Yes we are.
james
Chicago
Thank you kind sir.
Mike
Toolbox149
Hello.   Thought I would re-start this thread, rather than start something new.
My good ol' Audire preamp has given up the ghost and I think a Bryson BP20 or BP25 would continue and maybe improve on the the warm, crystal clear sound of my Audire.
I definitely will want to have a BP20 or BP25 - with the MPS-1 power supply ultimately incorporated.  Somehow I get the idea from reading here, that not all BP20s/ BP25s are capable of accepting the MSP-1 upgrade if the Preamp originally came with the BP-PSR power supply.  Is that correct, or will a MPS-1 work with any/all BP20s and BP25s?
PierreB
Hi James,
I'd like to know the retail price in $CAN for the power supply MPS-2.
Also is it possible to upgrade the parts in my BP-25 and I still use my MPS-1.
Hi James,
Hi
Power Supply is $1860 list.
Email Mike on the upgrade question please. - mpickett@bryston.com
james
PierreB
Toolbox149
Pierre;
"Also is it possible to upgrade the parts in my BP-25 and I still use my MPS-1?"
After you talk/email with Mike at Bryston, I would appreciate it if you would post the answer here.  I was wondering if that was possible too.  I've just been asking too many questions.
PierreB
Pierre;
No problem. I send him a message and wait for his response.
XMAN
The older BP20's with the switch on the preamp are not upgradable.  If you unit has the power switch on the power supply it can be upgraded.  This is my understanding.
Toolbox149
Xman;
Thank you for the info.   That is what I needed.  Unless somebody has some additional input, I'll be looking for a power switch on the power supply unit before I buy.  (Of course, it would make things very easy if someone sells a BP20 or BP25 with a MPS-1 already included).
PierreB
Here is the response from Mike:
"Hi Pierre;
There is very little that can be done to upgrade a BP25 without changing the
power supply.  In fact, the BP26 is very much the same as a BP25, other than
the power supply...
Mike"
I will keep my BP25 with it's MPS-1. For me they soud marvelous. :thumb:
It's a great preamp. No need for more.
Toolbox149
Thanks Pierre!
The info was helpful.  Now all I have to do is wait until someone sells a good quality BP20 pr BP25 at reasonable price, preferably with a MPS-1 already attached.    :drool:
PierreB
Thanks Pierre!
Good luck.
