Musica Bella "BellaMax" Custom Tube Preamps
0 Members and 1 Guest are viewing this topic. Read 6727 times.
Bill Baker
    • Musica Bella Audio
« on: 2 Jun 2009, 01:37 pm »
The Musica Bella "BellaMax" preamplifier shown below will be completed soon and will then be made available for sale. I will provide internal pictures of this unit when completed.
Key features of this unit:
* Full Metalized Poly Capacitor power supply
* Ultra Fast - Soft Recovery diodes by Fairchild
* New Paper in Oil coupling capacitors with high quality Poly Film bypass.
* DACT stepped volume attenuator
* Grayhill source selector
* Musica Bella MB Series internal wiring housed in Carbon Infused covering to further reduce noise potential
* Silver RCA input and output jacks
* 4 sets RCA input / 2 sets RCA output
* Adjustable gain switch (rear panel)
* Cryo treated Silver fuse holder - 1/4" x 1 1/4"
* Gold Audio Note knobs or brushed aluminum
* Five year warranty.
* Solid 3/4" Bubinga chassis with Quilted Maple sides and top
 Pricing will be in the area of $3,400 + shipping
 Feel free to ask any questions.
 Actual Unit
« Last Edit: 18 Jun 2009, 01:11 am by Response Audio »
poseidonsvoice
    • 2 channel/7 channel setup
Re: Musica Bella "BellaMax" Custom Preamp
« Reply #1 on: 5 Jun 2009, 07:16 pm »
 :drool: :drool: :drool:
mgalusha
« Reply #2 on: 5 Jun 2009, 07:27 pm »
Beautiful, just beautiful and from the sounds of it equally tasty inside.
Big Red Machine
« Reply #3 on: 5 Jun 2009, 07:32 pm »
Can you provide balanced connections?
Bill Baker
« Reply #4 on: 6 Jun 2009, 12:53 am »
Thanks for the kinds words and drooly faces :D
 We do have balanced units but not in these pieces. Only the Purity Extreme, soon to be officially released, will be equipped with balanced inputs and outputs.
rpf
« Reply #5 on: 6 Jun 2009, 04:40 am »
Not enough   :drool: :drool: :drool: :drool: :drool:
Absolutely Gorgeous!!!
Bill Baker
« Reply #6 on: 9 Jun 2009, 02:04 am »
Thanks rpf,
 I have a few other neat ideas in mind as well with some beautiful Japanese Tamo Ash I just came across :drool:.
« Last Edit: 14 Jun 2009, 06:17 pm by Response Audio »
Bill Baker
« Reply #7 on: 18 Jun 2009, 01:10 am »
Below is another custom BellaMax that is currently being built and up for grabs. The main part of the chassis is made of 3/4" solid Maple. The non-removable top is 3/4" Baltic Birch Ply. The veneer is some beautiful Japanese Tamo Ash real wood veneer. Metalized Poly capacitors throughout the power supply, DACT stepped attenuator, Grayhill source selector. Knobs will be brushed aluminum. Rear panel gain switch allowing for either 22dB or 16dB output. the unit will have 4 sets of line level inputs and 2 sets of line level outputs. This piece was designed with two full aluminum sheets to better help reduce interference. The tubes and circuitry are mounted on the underside of the top piece and the removable bottom piece allows access to the internals.
As shown below, there is not yet any clear coat.
Price: $3,650 (- 20% B-Day discount till June 26th)
1000a
Re: Musica Bella "BellaMax" Custom Tube Preamps
« Reply #8 on: 18 Jun 2009, 01:53 am »
OMG that is absolutely stunning :drool:
Bill Baker
« Reply #9 on: 18 Jun 2009, 01:33 pm »
Thanks 1000a. You should see it with some finish on it!
Bill Baker
« Reply #10 on: 24 Jun 2009, 02:07 pm »
Here we have the first coat of finish.
« Last Edit: 12 Jul 2009, 03:14 am by Response Audio »
Bill Baker
« Reply #11 on: 12 Jul 2009, 03:19 am »
Now we have a few more coats of urethane and some knobs installed. The knobs are solid Macassar Ebony but the purchaser of this BellaMax will their choice of just about any hardwood we can get our hands on.
« Last Edit: 28 Jul 2009, 10:08 pm by Response Audio »
Bill Baker
« Reply #12 on: 14 Jul 2009, 03:03 am »
Inside a BellaMax
For details, see the first post in this thread above
Bill Baker
« Reply #13 on: 16 Jul 2009, 05:43 pm »
Both pieces above have been spoken for.
I am also working on another piece for a customer that is using a 1" thick Macassar Ebony front panel with Maple over the rest of the chassis. The front panel will have a window in front showing the tubes. It is a remote volume unit as well. This piece will also have the "PhonoMax" phono stage built in.
 Should be a slick looking unit
Bill Baker
« Reply #14 on: 22 Jul 2009, 02:35 am »
« Last Edit: 28 Jul 2009, 10:03 pm by Response Audio »
Bill Baker
« Reply #15 on: 28 Jul 2009, 10:00 pm »
The unit below is being custom built for as customer and AC member that is upgrading to the BellaMax from the Bella L/P. The front panel is 1" thick solid Macassar Ebony with Maple veneer over Baltic Birch for the rest of the chassis. The clear extruded acrylic front window (shown below with protective film) will be a view to two of the 12AU7 vacuum tube for the analog stage. Within the chassis there are also two more tubes for the built in "PhonoMax" phono stage. Not yet shown are the two control knobs that will be used for the power switch and source selection. Volume will be handled by a custom remote control circuit. This is the last piece to be built with the removable hinged top.
