0 Members and 1 Guest are viewing this topic. Read 5258 times.
I would think that the panels should be at the speaker level. If the center of the speakers is at...say 28 inches, then the panels need to be centered at that point too. Doesn't that make sense?Wayner
In the corners, there MAY be a benefit in covering the tri-corners. On the side walls, I recommend starting them 18-24" off the floor - especially if the speakers are very close to the side walls.Bryan
Instead of trying to hang them, make a base, like a little stool/step thing. Attach the base to the wall using a couple of little L-brackets and just lean the panel on your little base.-C
What is SBIR control?
Next steps will be to add some panels to address ceiling reflection points and perhaps traps for wall-floor intersectionge
