port converter
0 Members and 1 Guest are viewing this topic. Read 1536 times.
EARGASM
  • No thanks.
port converter
« on: 1 Jun 2009, 01:29 am »
Hiya Mr. Clark!
I found this nifty port converter from round to slot. I know volume is volume, but this sure makes some quick work of it! Sorry if it has already been posted elsewhere...
http://www.bcae1.com/temp/simpleportconverter.swf
- Eric
S Clark
Re: port converter
« Reply #1 on: 9 Aug 2009, 01:52 pm »
Eric,
I had a kid put this to use this weekend.  Thanks for the link since it definitely makes construction easier.
Scott
Silicon
  • WHS- Blizzards.
Re: port converter
« Reply #2 on: 28 Jan 2010, 02:36 am »
Can this converter work for vehicle boxes?
S Clark
Re: port converter
« Reply #3 on: 28 Jan 2010, 05:31 am »
Sure, a box will behave the same whether in a vehicle or in a designated listening room.  Obviously, the acoustics of the environments will be different.  This converter simply lets you make a port with a rectangular slot instead of a piece of pvc pipe.
