0 Members and 1 Guest are viewing this topic. Read 3781 times.
The Timepieces are extraordinarily inefficient and you better budget for either a multi-kilobuck hifi SS amp, or save your pennies and get the biggest baddest pro audio PA amp you can lay your hands on. They gladly soaked up 800 watts from my QSC amp and even lit the clip LEDS on big transients. Yikes! We had the volume trims on the QSC cranked and the preamp was nearing the end of its travel and although it was good 'n loud I was not ready to cover my ears or anything. The Odyssey coped very well, but you don't get the luxury of input LED readouts or anything to know how hard its being hit. Apparently that whole "high current" thingy, I dunno what that's all about. In any case, think gargantuan muscle amps for these things if you like it loud.
The bigger the speaker the further away one must sit from it for optimum sound if you ask me.
Even if I may be exaggerating the lack of bass one thing which I am not exaggerating is the lack of soundstage. I mean...imaging? Floating center image? Instrument "placement"? There was none of that where these were placed.
I must also confess that I liked a lot of Nathan's music, and some of it was Metal!
