Did I lose a tube? Part 2
0 Members and 1 Guest are viewing this topic. Read 1377 times.
randog
« on: 20 Dec 2003, 04:58 pm »
I need your opinions!
The matched pair of Sylvania GB 5751's that I bought for my Norh CD-1 were gold pins. One blew.
The guy who sold me them has located another that tests within 10% of my good one, but it doesn't have gold pins.
Should I take it or wait until I can find another with gold pins to match? In other words, do you think the sonic differences will be discernible?
Also, is 10% an acceptable range for matching?
Randog
markC
« Reply #1 on: 20 Dec 2003, 11:57 pm »
IMHO 10% is acceptable, but if it ain't a gold pin, it aint the same tube.
randog
« Reply #2 on: 22 Dec 2003, 10:49 pm »
I was afraid of that.  :(
Can I get another tubophile to concur with Mark?
Same tube but steel pins in one and gold in the other = no-no.  :nono:
Randog
Wheezer
« Reply #3 on: 23 Dec 2003, 05:42 am »
Quote from: randog
I'm coming at this from a hobby-radio perspective, so I'm sorry if this is apropos of nearly nothing, but I wouldn't rule out a replacement based on gold-plated pins versus unplated.  If one is merely talking about a "ruggedized" (versus non) tube, it should in fact be "the same."  (I don't mean to pooh-pooh the matching of tubes.)  I guess I'm confused about that "10%" figure (10% of what?).  Plate current?
randog
« Reply #4 on: 23 Dec 2003, 01:33 pm »
It just means they test within 10% of each other on a tube tester.
Randog
Wheezer
« Reply #5 on: 24 Dec 2003, 01:59 am »
Quote from: randog
Not knowing the kind of tester, I'd guess the metric is plate current.  The effect of gold plating on the pins I would think to be negligible in comparison with +/-10% current.  If the replacement is being offered gratis for the failed tube, I wouldn't sweat it--the 5751 apparently has slightly lower gain compared with a generic 12AX7, but one could always view the situation as an opportunity for blind A/B listening.
In any event, you might want to keep an eye on the Glowbugs mailing list; "www.tubeman.com" also claims matched GE 5751 pairs for about $50 (no affiliation on my part, nor have I done business with them).
I'm probably out of my depth here, though, so I'll just wish you good luck.
