Resistor mod needed on Cornet to run directly into amp?
0 Members and 1 Guest are viewing this topic. Read 1440 times.
theclipper
Hi All,
I have been enjoying my Cornet and have been able to reduce the hum.  I have been auditioning new amps lately and have been told that a resistor mod was needed to get the Cornet to sound the best with a standalone amp.  The amp has a volume control so I am not sure if it is necessary or not.  I believe Jim has explained this before but I did a search and couldn't find anything.  If anyone could help me out I would greatly appreciate it.
Thanks much!
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
Re: Resistor mod needed on Cornet to run directly into amp?
« Reply #1 on: 29 May 2009, 11:30 pm »
Let me slide in here with a question about how you reduced hum.
hagtech
« Reply #2 on: 31 May 2009, 07:06 pm »
I don't remember any CORNET2 modification.  Just that it helps to keep the loading of the volume control at 10k ohms and higher.
jh
theclipper
« Reply #3 on: 31 May 2009, 09:21 pm »
Thanks for the Reply Jim.
I just remember tubesforever mentioning something.  I have the original Cornet though, with CCS mod.  Would there be anything you suggest to make sure I am getting the best sound possible running it directly into an amp.  Right now I am trying out the Eico HF 87 amp.
Also, how would I know if the volume control loading was about 10K?  I apologize for being so new with all this stuff.
Thank you,
Clipper
theclipper
« Reply #4 on: 31 May 2009, 09:22 pm »
I ran some jumper cables from a screw on the transformer to a metal board sitting underneath the Cornet.  I also ran some jumper cables from tube shields over the 12AX7s to a couple scews on the chassis.  That seemed to help quiet it down a bit.
PatOMalley
« Reply #5 on: 31 May 2009, 10:03 pm »
I have ordered a couple tube shields. I will wrap/seal them with copper film[faraday cage]. They will screw down to the chassis, which is grounded. Crazy how this tiny bit of hum can nag.
