Help Bryston 7B SST pair verus 14B SST ???
0 Members and 1 Guest are viewing this topic. Read 1076 times.
crimsondonkey
« on: 29 May 2009, 03:55 pm »
Both C-series so wondering whether there's significant functional or sound difference between these two excellent amps.
Also can 120V versions be easily adapted to run UK 240V mains supply?  Is this difficult, can a dealer do it?
Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Help Bryston 7B SST pair verus 14B SST ???
« Reply #1 on: 29 May 2009, 04:30 pm »
Thanks.
Hi,
There are a fair number of changes including transformer changes , labelling changes, capacitor and resistor changes going from a 120v to a 240 volt so it is definitely not something a Dealer or Distributor could do.
james
