DB1 wall mounts
0 Members and 1 Guest are viewing this topic. Read 2149 times.
gaderson
DB1 wall mounts
« on: 29 May 2009, 06:58 am »
I've been putting together an all PMC surround set (GB1+ LR & DB1-Ci center), and finally acquired a set of DB1+s for my surrounds, and would like to wall mount them as they seem to be the only PMC speakers, besides the wafers, that can be wall mounted. So, I called up a pro-audio dealer and ordered as set, but he recently email me to say he hasn't heard back from PMC on the order. Does PMC-America keep them in stock?
mvwhiting_83
  • Ask me speaker related questions!
    • PMC Speakers
Re: DB1 wall mounts
« Reply #1 on: 31 May 2009, 03:01 am »
We absolutely stock these...
gaderson
Re: DB1 wall mounts
« Reply #2 on: 31 May 2009, 09:56 pm »
Yeah, I got the conformation email from them late in the week. Now I just need to order new speaker cable.
p.s. are their other ways to mount PMC speakers besides the DB1 wall brackets? James Tanner has noted that he uses CB6s for surround channels, and if was to upgrade that sounds like an interesting addition--but, vertical or horizontal as both could be helpful to me.
  • The Demo is Everything!
    • http://www.bryston.com
Re: DB1 wall mounts
« Reply #3 on: 31 May 2009, 10:19 pm »
Hi gaderson,
Yes I used 2-centers as rears but had them on top of some tube traps.
james
gaderson
Re: DB1 wall mounts
« Reply #4 on: 8 Jun 2009, 08:15 pm »
Ok, now that I've got one set of speakers up I have to say these brackets are quite impressive, very sturdy, and I really like the little touches, like the 'set screw' so you can adjust the tilt of the speaker. Though I wish there was an easy way to make sure you get them level once fully fastened to the wall.
Oh, and clarification, they come in pairs or singles?
mvwhiting_83
    • PMC Speakers
Re: DB1 wall mounts
« Reply #5 on: 8 Jun 2009, 08:20 pm »
In pairs.
gaderson
Re: DB1 wall mounts
« Reply #6 on: 8 Jun 2009, 08:57 pm »
In pairs.
According to my dealer, I was buying each. But, I wanted two pairs anyway so thing's worked out.
