Using Icon as Power Amp
0 Members and 1 Guest are viewing this topic. Read 1171 times.
LFord
« on: 27 May 2009, 04:22 pm »
Hi,
New NuForce customer here -- I've got an AVP17 and an Icon w/ upgraded PS coming my way.   :D
I plan to try several applications with the Icon.  One of those is using it as a power amp for the rear speakers in a surround setup.  As the NuForce webpage says, "As a high-quality auxiliary power amp in a surround-sound setup, the Icon can be used to drive tweeters or rear-channel speakers."  So, I'm assuming I can just take the rear-channel outputs from the AVP17 to the RCA inputs on the Icon and then dial-in the volume to get the right blend.  Am I wrong in this?  Anything else of which I should be aware?
Lou
nuforce-casey
Re: Using Icon as Power Amp
« Reply #1 on: 3 Jun 2009, 05:39 am »
Hi,
No problem to run AVP17's rear surround RCA into the Icon for rear speakers.
