0 Members and 1 Guest are viewing this topic. Read 6953 times.
You can get muffin fans from Digikey for reasonable money. They are avalible in a variety of voltages from 12, 24, 48 DC and a 120 AC volt version. They move descent amount of air and are very quiet.http://parts.digikey.com/1/parts-kws/muffin-fanHere is another place:http://www.drillspot.com/products/48983/Dayton_4WT48_Square_AC_Axial_FanYou have to order the cordset seperately. It plugs into 2 terminals on the fan. We used these at work all the time.Wayner
Electrolytics hate heat- they can dry up. Transformers dislike heat too.
If the tubes have ventilation holes near them, then you could just force air through the chassis and out the holes
Quote from: JohnR on 4 Jul 2009, 04:41 pmIf the tubes have ventilation holes near them, then you could just force air through the chassis and out the holesThey do, but they already run cool because of the design and lay out.
