stylus force gauge?
0 Members and 1 Guest are viewing this topic. Read 1427 times.
orientalexpress
stylus force gauge?
« on: 26 May 2009, 01:53 am »
what is standard setting for Hi output MC?or low output MC.what is the minimum or maximum force .or play by ears.
Thank you
lapsan
galyons
Re: stylus force gauge?
« Reply #1 on: 26 May 2009, 02:33 am »
Thank you
lapsan
There is no "standard"  There are high, medium and low compliance carts. Follow the manufacturer's recommendation and tweak for best tracking with your ears and/or test record.
Geary
lcrim
« Reply #2 on: 26 May 2009, 03:22 am »
Most manufacturers will post a range of VTF for a particular cartridge.  I usually try the high end of the range as a starting point.
A bit too heavy is better than having the cartridge jumping out of the groove and damaging the record.  Far more damage is caused by setting the force too low than too high.
chosenhandle
« Reply #3 on: 26 May 2009, 01:42 pm »
if you don't know the suggested tracking force, you can probably find it online at cartridgedb.com
orthobiz
« Reply #4 on: 26 May 2009, 06:06 pm »
cool site, had no idea it even existed!
Paul
