BDA-1 Question
0 Members and 1 Guest are viewing this topic. Read 1386 times.
Dilbert
BDA-1 Question
« on: 24 May 2009, 04:35 pm »
My BDA sends a 44.1 khz output when there is a 48 khz input. Will it downconvert all the other possible input types as well?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-1 Question
« Reply #1 on: 24 May 2009, 05:10 pm »
Hi Dilbert,
Not sure on that -I have never used it - will check with engineering.
james
Re: BDA-1 Question
« Reply #2 on: 26 May 2009, 02:18 pm »
Hi Dilbert,
I assume when you say 44.1 out with a 48K feed your talking about the SPDIF output on the rear of the BDA-1?
james
Dilbert
Re: BDA-1 Question
« Reply #3 on: 27 May 2009, 06:19 pm »
Yes sir. Now, I am assuming it is giving me 44.1 because my CDR is accepting it for recording purposes.
Re: BDA-1 Question
« Reply #4 on: 27 May 2009, 08:10 pm »
OK then something is a-miss - the SPDIF out on the BDA-1 is simply a 'passthrough' so it does not affect the incoming signal?
james
Dilbert
Re: BDA-1 Question
« Reply #5 on: 29 May 2009, 02:01 pm »
This is very interesting. I wouldn't think my Sony semi pro CDR would record anything but a 44.1 signal, since it is the red book standard.
I wish I had a more high res unput available to see what happens, when I try to record. Has anyone here tried it out?
