Silicone oil for arm lift
0 Members and 1 Guest are viewing this topic. Read 1340 times.
Walterwalter
« on: 21 May 2009, 08:56 pm »
Which silicone oil to choose, that will fit the standard arm lift?
TheChairGuy
Re: Silicone oil for arm lift
« Reply #1 on: 22 May 2009, 12:07 am »
Walter,
300,000cst should do it.  Tim at TurntableBasics.com is a good fella' if you're in the US (don't know if he ships outside of borders)
http://turntablebasics.com/silicone.html
It's often tough to get in there to add the goo, tho (unlike good for pivot of paddle damping for tonearms)
Regards, John
