Foolbar2k with SRC or JRiver with ASIO4ALL v2 ?
0 Members and 1 Guest are viewing this topic. Read 1391 times.
oris98
« on: 21 May 2009, 08:11 pm »
Hi all,
Does any body has a chance to comparing the sound qty between Foolbar2K with SRC vs Jriver (media Jukebox) with ASIO4ALL v2 ?
Steve, in your Off Ramp and Overdrive setup,  which setup will sound better ?   which player will you recommend more ?
According to ASIO4ALL v2,  it bypasses the Window Kmixer for better sound qty..  Is Foolbar2K with SRC bypassing kmixer also ?
Many thanks.
audioengr
Re: Foolbar2k with SRC or JRiver with ASIO4ALL v2 ?
« Reply #1 on: 21 May 2009, 10:42 pm »
I have not tried Jriver myself.  I am a little suspicious of ASIO4ALL.  I use XP and unmap instead.
Steve N.
