Custom 845 monos w/ Tango transformers
0 Members and 1 Guest are viewing this topic. Read 65469 times.
Unison845
Re: Custom 845 monos w/ Tango transformers
« Reply #100 on: 11 Jun 2013, 06:39 am »
This is the amplifier frequency response at 20W into 8 ohms load, with zero feedback.
« Last Edit: 12 Jun 2013, 06:53 am by Unison845 »
J-Pak
« Reply #101 on: 12 Jun 2013, 03:56 am »
I used Tango NC15 (the white one on the right) , mounted underneath the chassis.
I dont want to use input transformer because you will need a preamp with 600 ohms output. Also good quality input transformer is expensive.
You must have a nice stash of Tango transformers  :green:
IMO good input transformers are quite a bit cheaper than the going rates for old Tango IT/OPT. Cheaper than the good Tango ISO as well.
Unison845
« Reply #102 on: 12 Jun 2013, 06:52 am »
I have not tried many input transformer (600: 15K-20K), but I did tried some UTC A11, LS151, and I prefer Input gain stage with tube. There is always pros and cons, unless you have a really good input transformer with great bandwith, and a low impedance source to drive it, I think input tube has advantage, yes tube does adds its own coloration, you have to choose one that matched your system, but it will sound more dynamic than any passive device.
Unison845
« Reply #103 on: 16 Jun 2013, 10:03 pm »
BAD NEWS, really BAD NEWS:
http://www.diyaudio.com/forums/tubes-valves/237596-iso-tango-quite.html
I guess Tango is shutting the door for good this time!
« Reply #104 on: 16 Jun 2013, 10:34 pm »
This 2013 year is being awful for many persons and companies, except banks.
More one year of crisis.
pulinap
« Reply #105 on: 12 Jul 2013, 07:22 am »
Any idea why they are shutting down?
Unison845
« Reply #106 on: 12 Sep 2013, 05:19 pm »
I did put an order for Tango 2 weeks before shutdown, they did not take my order.
Unison845
« Reply #107 on: 18 Mar 2016, 01:29 am »
That was Sep 2013, Tagon ISO closed their doors. March 2016, after two years and a half, I received the first new Tango transformers from Wavac and design them in my WE21E mono block amplifiers. It's a GM70 driving we212E amplifier.
JakeJ
« Reply #108 on: 18 Mar 2016, 02:58 am »
Wow!  Please post a picture of them in full glow.
Unison845
« Reply #109 on: 18 Mar 2016, 05:37 am »
Listen to WE 212E with stacked Quad/Janszen at night.
JakeJ
« Reply #110 on: 18 Mar 2016, 11:09 am »
Nice!  Thank you.
Guy 13
« Reply #111 on: 18 Mar 2016, 11:48 am »
Nice ambiant mood-light and great sound I am sure...
Thanks.
Guy 13
arthurs
« Reply #112 on: 18 Mar 2016, 02:04 pm »
Where are you located?
Unison845
« Reply #113 on: 18 Mar 2016, 03:30 pm »
Bay area.
arthurs
« Reply #114 on: 18 Mar 2016, 04:57 pm »
Great looking work!
Unison845
« Reply #115 on: 20 Sep 2019, 02:49 am »
Amplifier for Stax Electrostatic Headphones. The Staxes sound amazing with SE DHT amplifier. Here is an 845 SE amplifier tested few STax headphones , vintage from 1975 to 2018.
driving Staxes.
« Reply #116 on: 20 Sep 2019, 02:53 am »
Wow, I dont mind to be your neighbour...
Unison845
« Reply #117 on: 20 Sep 2019, 02:58 am »
My Horn active system 2017  , with 6 tube amps and a solid state amp (for sub) with active crossover.
DaveC113
  • ZenWaveAudio.com
« Reply #118 on: 20 Sep 2019, 01:45 pm »
WOW! Thanks for posting.  :thumb:
« Reply #119 on: 20 Sep 2019, 01:53 pm »
How does it sound?
