Computer Furniture
0 Members and 1 Guest are viewing this topic. Read 3811 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Computer Furniture
« Reply #20 on: 21 May 2009, 11:21 am »
Hi Werd,
I got and ripped most of the recordings off DVD's that were sent to me from RR and Chesky.  The 176/192k files are too large (250M to 450M per song!) for typical online downloads.
I have a vinyl setup (Roksan and Rega) and there are still differences in sound between vinyl and hi-res digital so I do not think going hi-res digital playback would necessarily replace vinyl.
Your correct though that assembling a hi-res digital system (not to mention making sure all the settings are correct and optimized) is not an easy task.  I assume this will get to be a more 'plug and play' proposition as we move forward. My prediction is that HIGH END computer playback will take on a similar behaviour as high end audio has now which will manifest itself as many different opinons on what computer with which sound card with which software sounds best!
james
« Last Edit: 21 May 2009, 12:50 pm by James Tanner »
werd
« Reply #21 on: 21 May 2009, 10:47 pm »
Hi Werd,
james
Hi James
With your experience with 192k,  would you say that there are more benefits in  playback than just the  digital filtering that 192k generates? I imagine it would sound different than what your upsampling offers on your BDA1?
« Reply #22 on: 21 May 2009, 10:57 pm »
Hi Werd,
The 'Native' 192 sounds very 'organic'.
I have to say though that I am finding the quality of the original recording whether upsampled or native seems to matter much more than any other factor.
james
werd
« Reply #23 on: 21 May 2009, 11:06 pm »
Hi Werd,
james
I like organic....... so then it would be safe to say that discreet output circuitry here is more at play than the bit count?
« Reply #24 on: 21 May 2009, 11:27 pm »
Hi Werd,
james
Yes it's a good question and I would say that the areas we paid attention too when designing the BDA-1 External DAC, like discrete output stage, dual power supplies, separate ground planes etc. has a lot to do with the way the BDA-1 sounds.
In the Golden Ear Award we recently got the reviewer mentioned to me that every source he tried with our DAC sounded excellent.
james
JP78
« Reply #25 on: 22 May 2009, 12:42 am »
hello,
i've built several silent home theater personal computers in the past, including everything from built in-navigation screen (like the levinson 502) to drive bays with firewire cards supporting the output rates you're asking for.  it's not something i do for work, but i'm happy to help if you'd like to take on a challenge.
« Reply #26 on: 22 May 2009, 12:50 am »
hello,
Hi JP,
Sure - where do we go from here?
james
