0 Members and 1 Guest are viewing this topic. Read 6272 times.
Its true that X watts is Y volts rms into a 8 ohm load, but that doesn't quite paint the whole picture as the test conditions are generally a 8 ohm resistive load, not the 8 ohm reactive load of most speakers.
So then does maximum peak and maximum continuous current ability mean anything when judging a power amplifier?
The way I look at power, power is often stated as a 1 dimensional statistic X watts at 8 ohms and sometimes(often) also stated at 4 ohms. This is a two point approximation of 2 dimensions. The problem of power into a speaker is more of a 3 dimensional problem. Power by impedance by frequency (usually only stated/tested at 1khz where speakers are typically their most benign).
JoshPlease move this thread to the trash bin and I rework my question. Thanks Adrian.I apologize for not doing a lead in to the post. I came here for help as to the correctness of the email that was sent to me (Adrian). It is from someone I am considering doing business with and I just wanted to know if what I was being told was correct.If that is dirty laundry than again I apologize but if I can't come here for answers where would you direct me to.And thanks for the answers.RegardsAdrian
Quote from: JoshK on 20 May 2009, 01:27 amIts true that X watts is Y volts rms into a 8 ohm load, but that doesn't quite paint the whole picture as the test conditions are generally a 8 ohm resistive load, not the 8 ohm reactive load of most speakers. This is the crux of the question. Power is voltage x current x cos(phase angle)If you have a constant voltage amp then the more reactive the speaker then the more current the amplifier has to deliver to produce the same power-- to the point where phase angle is 90 degrees and the amplifier can not deliver any power.Lonnie, if your amplifier can only deliver sufficient current to meet its rating into a resistive load than it will not meet that rating into a real loudspeaker.dave
......For myself I look for an amplifier that will at least double it's 8ohm rms power output into 4ohms as this tells me something about the power supply capabilities of the amp. Scotty
The PowerCube test
Quote from: turkey on 20 May 2009, 12:22 pmThe PowerCube testCan you post a picture of the graphic generated? This sounds like a useful test.dave
Here's the company that makes the test equipment:http://www.audiograph.se/
Those Parasound measurements look fantastic till you get to Figure 4. I'd like to see the FFT at 1w and say 10w. Note how THD+N goes down until 5-10w, then back up gradually, typical of an amp with lots of feedback. I am not trashing this amp. But to my eyes the Fig 4 looks pretty ugly, exactly what the low power crowd tries to avoid. However, almost no listening is done at 250w unless you are driving Maggies, Apogees or B&W 801s.
