Bryston Step Up Transformer
0 Members and 1 Guest are viewing this topic. Read 3220 times.
Dilbert
« on: 19 May 2009, 03:34 pm »
James (or anyone else, who may know), could you talk about this device? Technical specifications, history, anything that you would not mind sharing?
Thanks in advance.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Step Up Transformer
« Reply #1 on: 19 May 2009, 03:39 pm »
Thanks in advance.
Hi,
It was called the TF-1 and was a MC outboard setup transformer (cause the transformer is the PROPER way to stepup a MC cartidge).
It is the same transformer we still use today in our MC Phono Stages. They are extremely expensive to make.
http://bryston.com/bp15spec.html
james
Dilbert
« Reply #2 on: 19 May 2009, 03:46 pm »
Thanks James, that was quick!
« Reply #3 on: 19 May 2009, 03:48 pm »
Thanks James, what was the voltage gain, when appropriately loaded?
Sorry - not sure I understand the question?
Gain other than what is shown in the Specs?
james
Dilbert
« Reply #4 on: 19 May 2009, 03:49 pm »
It's okay, everything I need is on the link. Thanks again.
