0 Members and 1 Guest are viewing this topic. Read 7361 times.
Well, I guess like trips the length of like 20 to 50 miles is what I used to ride on my other bike.Casual riding yes. Excersize trips.Brands... We've got them all I think:Scwinn, Scott, Cannondale, klein, all of them, and therein lies the problem... how does one choose!So thanx for the tips! Keep them coming!Imp.
I have several Jamis bikes and they are comparable in quality to most of the other major brands, but you generally get a better component spec than similar priced models from other companies. They're a little harder to find, but are good values.http://www.jamisbikes.com/usa/index.htmlLike others have said, fit is probably most important, and then finding the type of bike that matches your riding environment. I'm mostly a fireroad type rider, and over the years have gone retro with a non suspension steel frame, the tires provide all the suspension I need - and I enjoy the ride more. I'll now only ride the full suspension bike on single track, or in the snow. Jim C
