0 Members and 1 Guest are viewing this topic. Read 2313 times.
...Correctly uncompressed Flac is the same as WAV, bit for bit. But the processor that decodes the flac can vary in its abilities. Squeezebox is audible difference between flac and WAV, but if you use a good PC player you probably won't hear it...
