Fixing up an old Marantz SR6000G
0 Members and 1 Guest are viewing this topic. Read 1309 times.
BradJudy
« on: 11 May 2009, 04:01 pm »
I ran across a Marantz SR6000G at a local thrift store for $20, so I picked it up to play with.
It powers up, but appears to be stuck in protect mode ("Protector" as it's labeled).  Naturally this means no sound and I'm hoping that it's something I can fix and not a blown driver (STK module), since I don't know if you can readily get replacements.
It needs a bit of cleanup, but the tuner section seems to work (needles move as I tune even if the output section is shut down.
Any recommendations on where to start on troubleshooting the protect mode?  I have multimeters, soldering skills and some knowledge, but no great knowledge or other test equipment.  I'll start a cleanup and visual inspection of components looking for blown/damaged items.
BradJudy
Re: Fixing up an old Marantz SR6000G
« Reply #1 on: 11 May 2009, 09:31 pm »
I had a chance to poke around at this a bit more.  I'm guessing out of the output devices is shorted since it appears to be putting ~50VDC onto one of the channel speaker outputs with a disconnected input selected (0VDC on the other).  So much for the protect mode doing much protection.
