help with Mac Os X
0 Members and 1 Guest are viewing this topic. Read 2353 times.
solomty
help with Mac Os X
« on: 11 May 2009, 02:15 pm »
Hy  .Could  someone  help me I want to load a new Leopard 10.5  in a old Mac G4 with OS 10.1 .I have the original Leopard .How could erase the 10.1 and load the 10.5 Help will be appreciated .Thanks form a Mac user  newbie .
PhilNYC
Re: help with Mac Os X
« Reply #1 on: 11 May 2009, 02:44 pm »
I think you just run Software Update and have it update the OS, right?  No need to erase the current version...
(go to the apple menu at the top-left of the screen, then select Software Update...)
Btw - what is the processor speed on your G4?  I think Leopard 10.5 requires at least 867mhz....
Crimson
« Reply #2 on: 11 May 2009, 03:00 pm »
Hello and welcome! As mentioned above, before doing anything, check to see what processor you have (click the apple at the top left and then click on 'About this Mac'). Per Apple, it will not install with anything less than an 867MHz processor (and even then the machine will be quite slow). If you still want to go ahead with the upgrade, backup all your important data and then simply insert the Leopard DVD and perform a clean installation.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #3 on: 11 May 2009, 05:59 pm »
My personal experience on my G4s has been less than stellar... i'd recommend 10.4.11 as the newest OS to run on them (don't even think about it if you don't have 1.5 to 2.0 GB of RAM). Any G4 , except possibly the newest ones will also require a DVD reader capable of reading the double layer DVD the install comes on.
I think it will probably be moot anyway, any G4 capable of running on 10.1, is unlikely to meet the minimum requirements for 10.5. If you bought a copy of Leopard to upgrade your OS (since it is the only one you can buy), any dealer worth their salt will install 10.4 for you.
dave
cryoparts
« Reply #4 on: 11 May 2009, 07:57 pm »
I've got 10.5 on my 1.25 PowerBook with 2G of RAM and it works great as a music serer.  I don't do anything but use this for a music server though.
But there is no way I would try it on my older iBook, or iMac, even though I am only using them for music servers as well.
Peace,
Lee
solomty
« Reply #5 on: 11 May 2009, 09:57 pm »
Hy  . Thanks  indeed  to everyone  unfortunately my G4 is a old computer with a family number M5183  with A 450 mhz CPU  AND 1 G OF RAM  . I want to change the OS10.1 because I would like to install a wifi card just  bought .  Could  another OS version  as 10.3  or 10.4  work  with the cpu aforementioned or must buy  a 900 Mhz cpu and install myself  . as said  earlier  thanks to everyone . :duh:
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #6 on: 11 May 2009, 10:23 pm »
You want to run 10.4 on that one -- you'll need a PPC install (intel & PPC installs are different) and it should auto-update to 10.4.11. I still have one printshop client that still has a number of these (400 & 450 MHz) running 10.4.11.
I routinely put these together as "internet applicances" for people with no money.
I also figure that the case will make a good home for electronics projects (i have 3 or 4 but haven't proceeded yet)
dave
PhilNYC
« Reply #7 on: 11 May 2009, 10:24 pm »
OSX 10.4 should work fine on your computer:
http://www.apple.com/support/tiger/
btw - fwiw, i run OSX 10.5 on a G4 iBook (1Ghz) with 640MB memory, and it seems to work fine...
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
« Reply #8 on: 12 May 2009, 12:14 am »
My advice is to repair disk permissions both prior to and following a OS upgrade.  Otherwise, you should be able to upgrade with the installer without incident.
solomty
« Reply #9 on: 12 May 2009, 10:26 pm »
  :scratch: :scratch:Thanks for  your  answer but could  tell me where can get the how to  make a repair  disk permission a tutorial or something alike .
oneinthepipe
  • Trainee
« Reply #10 on: 12 May 2009, 10:42 pm »
Applications - Utilities - Disk Utility
Open Disk Utility, select the startup disk (or disk or partition in which you wish to upgrade the OS), select First Aid, then click the Repair Disk Permissions button.  Done.  Run the new operating system's installer, select upgrade, install, restart, then open Disk Utility and Repair Disk Permissions again.
