LS9 Build
0 Members and 1 Guest are viewing this topic. Read 6105 times.
HT cOz
Re: LS9 Build
« Reply #20 on: 24 Jun 2009, 01:52 pm »
Maybe add a thin layer of baltic birch plywood?
PMAT
Re: LS9 Build
« Reply #21 on: 24 Jun 2009, 01:55 pm »
how about bondo?
Bill Baker
    • Musica Bella Audio
Re: LS9 Build
« Reply #22 on: 24 Jun 2009, 01:56 pm »
 That is a good thought. I know you can get Baltic Birch in 1/8" thickness and if I recall, 1/16" is available.
 If you really want to go over the top, how about solid hardwood strips maybe 1/8" thick and 4" wide running horizontally for the side panels :drool:
 Bondo will not do the trick on MDF do to the differences in expansion.
dvenardos
Re: LS9 Build
« Reply #23 on: 24 Jun 2009, 09:07 pm »
This may be blasphemy, but what if you glued 1/8" plywood to the mdf and then veneered the plywood?
edit:
 :duh: Htc0z beat me to up
« Last Edit: 25 Jun 2009, 05:34 pm by dvenardos »
fcraven
  • Don't mess with this baritone
Re: LS9 Build
« Reply #24 on: 24 Jun 2009, 09:48 pm »
Yep, typically called "aircraft plywood" (I think because it is used for model aircraft) I used it for Rockets.
The thinnest you can buy is 1/64". But that stuff comes in small sizes, like 3" x 24" or some such. (it's been a while)
I know you can get aircraft ply in large sheets, but you might need to look to a hobby source.
Midnite Mick
Re: LS9 Build
« Reply #25 on: 24 Jun 2009, 09:54 pm »
Being inspired by Usher speakers I was going to attempt to do this as well when I built a pair of speakers.  However, I found it rather difficult to rip down the hardwood to a thickness that would work.  I am not that skillful I guess.
Mike
S Clark
Re: LS9 Build
« Reply #26 on: 24 Jun 2009, 10:02 pm »
Better yet, ask Eric (Eargasm) about the extra thick veneer that he uses. I just can't see laminating plywood, and then turning around and veneering on top.  What about pre-veneered panels with inserts at the corners?
Daygloworange
  • www.customconcepts.ca
Re: LS9 Build
« Reply #27 on: 24 Jun 2009, 10:05 pm »
His best bet (and most economical) would be to glue down a sheet of 1/8" Masonite, and then veneer over that. It'll increase the width of the enclosure slightly, but it'll guarantee a flat surface to veneer over.
S Clark
Re: LS9 Build
« Reply #28 on: 24 Jun 2009, 11:36 pm »
I think Denny has a winner!
