0 Members and 1 Guest are viewing this topic. Read 8241 times.
Yes, the Roku Soundbridge.
I've read that the latest model of the SoundBridge, M1001, always upsamples all input to 48kHz and since CDs are 44.1kHz, there's a bit of noise introduced by the resampling. If your friends aren't audiophiles they might not notice the noise.An even cheaper option would be to get the Squeezebox Receiver for $149. It doesn't have a display or remote control (you'd have to buy the Squeezebox Controller for that), but you can still control it from the SqueezeCenter interface back on the computer.[edit] If you really want a remote to go with the SB Receiver, look for a used Nokia 770 on eBay. They go for around $50 and can be used to control the SqueezeCenter interface remotely. -Rob
I don't know if the coupon codes still work, but a bunch of us got Touchs for $229.
Another possibility would be the Squeezebox Radio for $130-150. Use the headphone out to connect it to a stereo.http://www.amazon.com/Logitech-Squeezebox-Radio-Player-Screen/dp/B002LARRDK
Digital Out is pretty much a necessity for me.
