0 Members and 1 Guest are viewing this topic. Read 8241 times.
another smart member learns the "secret" of our Powervar club. Can someone tell me the difference between a Powervar and Oneac?
Hope that helps
...Is it better to seperate source,pre ect or is this just because of the amperage ratings on the units?
Doug,How would you use this?http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2579598074&category=42881It's 480v in, 240v/120v 3 phase out.I don't think you can get 480 volt service to your house. That'd be for industrial use.And even if you did manage to get 480v service to your house, you can't use 3 phase power on single phase gear. And audio gear is only singel phase.
my point in referencing this is not that this is the best unit to get, or even a good one, but that keeping an eye on ebay for this type of equipment can result in truly superior performance for relatively little money. that item was yust a from a quick search, to give folk an idea of the kinda stuff that's out there... prolly the best unit of this type to find would be an isolation transformer w/220-to-120 stepdown... yure correct that i shoulda been a bit clearer...
my understanding, (courtesy of jon risch), is that digital artifacts can be sent back thru the power cables & into other equipment, which is why having separate isolation transformers for dac & transport is beneficial. everyting else could be on one isolation transformer, assuming its amperage rating is sufficient. i don't really tink one needs to worry about brands, tho theoretically, for digital gear, the units w/old fashioned square iron-core transformers are better than the toroids, cuz the toroid ...
