SP1.7 trigger to Arcam power amp
0 Members and 1 Guest are viewing this topic. Read 1069 times.
Slingshotx
« on: 6 May 2009, 03:05 pm »
Hi I had a quick search and couldn't find the answer.
I'd like to power on my Arcam power amp which has a 3.5mm mono jack with my Sp1.7 to act as a trigger, so my question is does anyone know if I should connect the common from the SP1.7 to the centre pin of the 3.5mm jack or the on/off output from the SP1.7 to the centre pin?
Thanks in advance
Slingshot
brucek
Re: SP1.7 trigger to Arcam power amp
« Reply #1 on: 6 May 2009, 03:41 pm »
The center pin of the 3.5mm plug is the positive from the SP1 and the shield of the 3.5mm plug is the common.
Slingshotx
« Reply #2 on: 6 May 2009, 03:49 pm »
Thanks very much for the quick reply, I'll get me soldering iron out tonight!
