Digital cable termination question
0 Members and 1 Guest are viewing this topic. Read 1614 times.
serengetiplains
« on: 5 May 2009, 02:28 pm »
Steve, I was thinking about XLR digital cable termination and have a question.  Take a properly designed digital cable.  Inside the cable jacket, the cable is designed to be, and is, 110ohm characteristic impedance.  That impedance results from the cable geometry (strand A at whatever distance from strand B with X dielectric etc).  To terminate this cable, one must separate the cable strands then solder them into the connector (here XLR).  Doesn't separating the strands change the characteristic impedance, therefore creating a source of reflections?  Can this problem be avoided?
Tom
audioengr
Re: Digital cable termination question
« Reply #1 on: 5 May 2009, 08:13 pm »
Tom
Sure, there will always be small discontinuities there.  There is XLR connector that purportedly minimizes this, but nothing like the crimp termination you can get with a BNC for instance.
I cant remember the make, it's not Canare or Cardas.  I would just use Neutrik.
Steve N.
BPT
  • Balanced Power Technologies
« Reply #2 on: 5 May 2009, 08:32 pm »
Tom:
Look at the Neutrik NC3FXCC.
Chris H.
serengetiplains
« Reply #3 on: 5 May 2009, 09:10 pm »
Thx guys.
audioengr
« Reply #4 on: 5 May 2009, 09:55 pm »
Tom:
Chris H.
does not say anything in the specs about impedance control, but the shielding is better I guess...
Steve N.
