Satin Black Finish Titan ... How to clean?
0 Members and 1 Guest are viewing this topic. Read 2065 times.
rockadanny
« on: 5 May 2009, 02:16 pm »
Or should I just buy a new one?  :lol:
Mike Dzurko
Re: Satin Black Finish Titan ... How to clean?
« Reply #1 on: 6 May 2009, 01:42 am »
Heck yes, just buy a new one  :)
Seriously, usually I just give it a quick dusting with feather mop or clean cloth.
rockadanny
« Reply #2 on: 6 May 2009, 11:15 am »
Thanks for responding Mike. I should have been more clear. The top has smudges all over it. I tried a lightly damp cloth but not strong enough. I suspect the smearing is fingerprints and whatever else my little nephew was eating at the time. My wife suggested Murphy's Oil Soap but I wanted to check with the experts first.
Anyone?
Mike Dzurko
« Reply #3 on: 6 May 2009, 02:58 pm »
The Murphy's . .  . might work, but might leave a residue. I have a note at home with something that should work well. I'll check tonight when I get home and post.
Mike Dzurko
« Reply #4 on: 7 May 2009, 01:23 am »
A good mixture is Ivory soap in water. You need VERY little soap, just enough to get some suds in warm water. A drop or two of soap in a glass of water for instance. Dampen and use a micro fiber cloth or other very clean cloth. Wipe it off, then wipe with a cloth dampened in just water. Finish with a dry cloth . . . will look good as new :)
rockadanny
« Reply #5 on: 8 May 2009, 05:31 pm »
Mike - followed your instructions ... bam!  :thumb:
Worked great! Thank you.
Mike Dzurko
« Reply #6 on: 12 May 2009, 12:09 am »
Actually, I need to thank my wife, she worked this out a couple of years ago by trial and error  :D
