Wall bracket for sealed HT1's
0 Members and 1 Guest are viewing this topic. Read 2357 times.
gchuva
« on: 5 May 2009, 02:48 am »
I'd like to have the flexibility of putting some sealed HT1's on the wall or on a bookshelf.  Does anyone have a suggestion for this?  I've asked Jim but he did not have a suggestion for the wall mount of the sealed HT1.  If I cannot find the wall mount then I am going with Song Surrounds.  Thanks for your help.
audiocrazy
Re: Wall bracket for sealed HT1's
« Reply #1 on: 12 May 2009, 10:40 pm »
I used B-Tech BT77 to mount Song Surrounds but they are not sturdy enough to hold them. One of my speakers slipped out of the mount and damaged the speaker cabinet  :x.
Just sharing my experience so be careful when mounting. Ask Jim if he can drill an eye hook in the speaker cabinet so that it can be tied down.
« Reply #2 on: 12 May 2009, 11:33 pm »
How much do they weigh?  Are they the same shape as the HT-1?  Do you mind drilling holes in the back?
jsalk
« Reply #3 on: 13 May 2009, 01:24 am »
I don't have any sealed HT1's at the moment and, therefore, do not know the weight.  They are 9" wide, 15" tall and 15" deep.  I would gues they weigh 35 pounds.  So the BT-77 will not work.
As for the BT-77 with SongSurrounds, I have a pair of very similar MBOW1's in my shop in a high vibration area and they have been hanging there for about 4 years - no problem.  We have quite a few other customers who use this clamp as well and seem to be very happy with it.
- Jim
randybessinger
« Reply #4 on: 13 May 2009, 07:35 pm »
Jim built some sealed HT-1's for me that had a great way of mounting them on the wall.  They would only walll mount though as the back is unfinished.
