Buzz with P1 and new Ortofon red cart
0 Members and 1 Guest are viewing this topic. Read 953 times.
TRM
« on: 4 May 2009, 06:32 pm »
Hi all, does anyone have experience with the Rega P1 and the Ortofon 2m Red? I installed the cart myself about 2 weeks ago and I'm noticing a buzz that is much louder than anything I ever noticed before the cart switch. I've double-checked the wiring and that is all correct. My understanding is that the P1 is grounded through the power cable.
Are there known issues with this cart/table setup? I haven't seen anything but perhaps I missed a post on the topic. How have other people grounded this setup?
Wayner
Re: Buzz with P1 and new Ortofon red cart
« Reply #1 on: 4 May 2009, 07:38 pm »
1. Have you double checked that the stylus is installed all the way?
2. Is your interconnect cable close to any transformers or a wall wart?
3. What phono preamp are you using and is it perhaps set for higher than necessary gain?
Wayner
