C20 ... Cornet
0 Members and 1 Guest are viewing this topic. Read 1575 times.
Laudanum
C20 ... Cornet
« on: 18 Dec 2003, 12:37 am »
OOPs ...
I had the old Cornet parts sheet when I ordered parts and thus didn't order the C20 ... .01 uf ac rated cap to go across the ac  line input.
I am using the Hammond 270BX so I'm not sure if there is going to be an issue with seemingly the 370's having the problems.
However, I do have a couple of caps that I didn't use for an older project.
These are Mouser # 75-30GAS10 ... page 482 in the current Mouser catalog at bottom of page.
Could somebody please take a look if you have a Mouser catalog or online and let me know if this cap is ok to use for C20 ... I would very much appreciate it.
It is rated for 1000VAC, 4kVDC ... but I'm not sure if that's the only criteria necessary for using it as C20.
Thanks very much!
hagtech
    • http://www.hagtech.com
C20 ... Cornet
« Reply #1 on: 18 Dec 2003, 07:36 am »
Yeah, that sounds ok.
jh :)
