0 Members and 1 Guest are viewing this topic. Read 8528 times.
You don't want to do any gain, if possible, in software
My whole reason for recording flat to begin with was to be able to do a perfect RIAA in the computer, not just to apply RIAA in the computer. The only way I know of to do this is record a pinknoise track off a test record using your flat preamp, then in the computer draw an RIAA curve using a powerful software eq such as the Waves Q10 so that a straight line is formed on your spectrum analyzer when frequency is plotted logarithmically against amplitude, which is plotted algebraically. If you haven't done this you aren't taking into account the frequency response of your cartridge and TT. And any change you make to your setup will change your flat recordings, necessitating a change to your RIAA curve, which means re-recording the pinknoise again with the new settings so you can change the curve.
Right, i meant internal processing (if any) at 32bit but 24/96 is more accurate, sorry. I look forward to getting into this discussion some more with you all. I wish I had my stereo set up right now; we're moving things around big time and no serious listening for a while now.best,Jon
"GRADOInductance: 45mHResistance: 475Input Load: 47KI cannot reproduce here the VISUAL results of the program used to render the following calculation, but here are the results. They will, as have other real world tests, throw into question the rationale that drives manufacturers to provide a standard 47k load for MM cartridges, as well as the recommendation that users so load ALL MM cartridges (The Shure V15VxMR, for example, would not behave anything like we see here; their engineers seem to have designed it to work into a 47k load). Here are the results and something I think you might find worthwhile and relatively inexpensive to try out:GRADO (45mH / 475d)With 200pF cable & stray capacitance and 47K load resistor, output starts to rise at ~10KHz to +1dB at 20KHz and a +9dB peak at 50KHz;With 300pF cable & stray capacitance and 47K load resistor it gets worse. Output now starts to rise at ~10KHz to +2dB at 20KHz and a +10dB peak at 42KHz;With 200pF cable & stray capacitance and 10K load resistor things look much better. Output is pretty flat to 20KHz and rolls off to ?3dB at ~45KHz;With 300pF cable & stray capacitance and 10K load resistor things look better yet. Output is ruler flat to 20KHz and rolls off to ?3dB at ~46KHz. In this scenario, the added capacitance actually helps.Whether or not your ears will hear the peak (it is ultrasonic & outside the audible range), it is probably not good anyway. You WILL hear a difference, and I think one which you will find favorable, at least based on what information we presently have about your system and what you are now hearing as "wrong."If you place a 13K resistor across the phono input plug, it will be in parallel with the existing 47K which is then 10K. It will let you experiment without modifying the preamp."
Syrah,If you are recording through a flat-response preamp and applying a standard RIAA eq curve in your computer, then the sound will be slightly different (to my ears better) than recording the sound from the low-output MC run through the standard phono stage. But for the better sound you need to use the best software available in a 32bit Floating Point environment. I don't know what you're using, but a $50 editor will not do this.The reason for the better sound is that most low-output MC have a peak in the frequency response at the high end and you are automatically correcting this when you adjust your software eq to apply a perfect RIAA curve, which I think is way cool, and you're automatically eliminating any other frequency deviations from the RIAA which may be introduced through your TT and cart setup. You would also be changing the signal to be absolutely flat all the way down to 20Hz, which is cool, but in the real world not necessary at all, since many recordings are rolled off during the mastering process at anywhere from 50-75Hz!But you're still better off doing the RIAA with your phono preamp. For instance, if you make any adjustment to your TT which changes the sound even slightly, such as height of the tonearm, tracking force, damping of the arm, etc, you are then required to change your RIAA eq curve in the computer, and it turns into a big can of worms. You end up spending all your time recording the pink-noise track off your test record through the flat-response preamp so you can get your RIAA curve right again, and it's not worth all the time spent doing that. It ends up being a whole lot easier to just play the record with a normal phono preamp where you can listen to the sound as it's being recorded, and do the eq later, or not. My approach now has been to upgrade my vinyl front-end and make sure it's set up correctly. Then, if I'm not liking the sound of an LP I "tune it" by varying the cart load, VTA, VTF, and damping. But ultimately the idea is to find the combination which sounds right on (almost!) every LP. Then you know you've got it right, and you can spend your time making music and not fiddling!When I was "into" doing the RIAA in the computer I tried plug-ins from all the manufacturers in my audio editor and the Waves software stood out as being ultra-transparent, very sweet-sounding, and without a doubt the best-sounding software I had ever gotten my hands on. I purchased enough of it as individual stand-alone plug-ins so that every single calculation that my computer makes is now done using a Waves plug-in.Are you making CDs from LPs? If so, my recommendation is just use a regular phono preamp. Take the money you would have spent on the Q10 and apply that towards getting the Waves Restoration Bundle. Everything they sell is available free to try for 2 weeks, but buy from a pro-audio dealer at reduced cost.
