Industry Circles
GR Research
Danny Richie
OB7 QUERY
OB7 QUERY
0 Members and 1 Guest are viewing this topic. Read 1481 times.
AUDFILE74
OB7 QUERY
3 May 2009, 03:31 am »
hi danny, i was wondering if you had a chance to test the ob7(neo3pdr,m130-16,m130x) in a freeair setup. how did thw ob7's overall freqresp change? or to rephrase, how low does the ob7 with m130x drivers play if all drivers are freeair?
Danny Richie
Facilitator
Re: OB7 QUERY
3 May 2009, 05:17 pm »
I used that combination in prototype that used a pair of the servo subs handling the bottom end. It used the Neo tweeter, M-130/16's in the middle and a pair of M-130X woofers in series helping to cover a little lower end. The crossover point to the servo subs still fell in the 200Hz range. You really can't push them much lower than that in free air without really giving up power handling.
trekker
Re: OB7 QUERY
Reply #2 on:
4 May 2009, 02:19 pm »
Danny,
I was wondering, instead of using a pair of M-130X woofers, could a pair of SW-12-16FR Servo Sub Woofers be used and crossover at 200Hz?
At least this way the system will be open baffle from the bass up the PDR's crossover point.
Danny Richie
Facilitator
Re: OB7 QUERY
Reply #3 on:
4 May 2009, 03:59 pm »
The M-130X woofers were in open baffle as well.
Industry Circles
GR Research
Danny Richie
OB7 QUERY
