0 Members and 1 Guest are viewing this topic. Read 10119 times.
Winnipeg Canada. BP26 linestage and the DAC. Both Black 17 in. thanks
Quote from: mitcho on 13 May 2009, 05:59 pmWinnipeg Canada. BP26 linestage and the DAC. Both Black 17 in. thanksOops sorry about that - I have a customer in Holland doing the same thing - weird!james
Quote from: James Tanner on 13 May 2009, 06:03 pmQuote from: mitcho on 13 May 2009, 05:59 pmWinnipeg Canada. BP26 linestage and the DAC. Both Black 17 in. thanksOops sorry about that - I have a customer in Holland doing the same thing - weird!jamesNah .... you just Alicia Keys on your brain.....
Ok, cool. Maybe later on you can get the Bryston phono stage in your preamp. I have one in my BP6P, and it is fantastic!
Quote from: vegasdave on 1 Jun 2009, 11:50 pmOk, cool. Maybe later on you can get the Bryston phono stage in your preamp. I have one in my BP6P, and it is fantastic!Dave,if i understand it correctly then you can either order a 26 line OR 26 dac OR 26 phono. it's not an usual ''upgrade'' to go from a 26 line to a 26 phono ??maybe James can tell us how it works...al.
Quote from: alexone on 2 Jun 2009, 05:13 amQuote from: vegasdave on 1 Jun 2009, 11:50 pmOk, cool. Maybe later on you can get the Bryston phono stage in your preamp. I have one in my BP6P, and it is fantastic!Dave,if i understand it correctly then you can either order a 26 line OR 26 dac OR 26 phono. it's not an usual ''upgrade'' to go from a 26 line to a 26 phono ??maybe James can tell us how it works...al.Hi All,Yes the BP26 can be ordered as a line,phono or DAC. You can not have phono and dac as there is not enough room in the preamp for both.If you add the DAC or phono later it can be done but the preamp has to have the facplate and the rear panel changed to accomodate the physical and label changes.james
thanks for the info. It's what I had anticipated since the mono/ stereo switch is changed on the front. I am fine with just the line stage. I like the flexibility of the external phono stage.
Quote from: James Tanner on 2 Jun 2009, 10:11 amQuote from: alexone on 2 Jun 2009, 05:13 amQuote from: vegasdave on 1 Jun 2009, 11:50 pmOk, cool. Maybe later on you can get the Bryston phono stage in your preamp. I have one in my BP6P, and it is fantastic!Dave,if i understand it correctly then you can either order a 26 line OR 26 dac OR 26 phono. it's not an usual ''upgrade'' to go from a 26 line to a 26 phono ??maybe James can tell us how it works...al.Hi All,Yes the BP26 can be ordered as a line,phono or DAC. You can not have phono and dac as there is not enough room in the preamp for both.If you add the DAC or phono later it can be done but the preamp has to have the facplate and the rear panel changed to accomodate the physical and label changes.jamesJust to let everyone know, you can have both phono and DAC the BP16.I wonder why more people don't have the BP16. It would have been my top choice, but I couldn't afford it.
