Cambre' audio rack FINAL clearance, over 70% off and free shipping!
0 Members and 1 Guest are viewing this topic. Read 2563 times.
carabeeno
Cambre' FINAL factory clearance of their low- and mid-priced lines, Entre' and Timbre', both audio and AV racks.  Featured here is the Entre' silver 4 shelf rack available with either silver or black aluminum tubes.  Cambre' research is partially funded by the well-known Canadian National Research Council and they are a leader in anti-resonance technology.  Cambre's website, cambreproducts.com, is currently under construction to delete these, so the best place to find out more about all the Entre' and Timbre' models being cleared out is here - http://69.89.238.79/prod/shopdisplaycategories.asp?hid=370&cid=370&sid=14&sname=Cambre.  The Entre' silver has a US list price of $350 and is now available for $99 shipped FREE anywhere in the continental US (we also have available a smaller quantity of black racks of the same type with black or silver posts for $119).  Buy several for complex systems.  Quantities are limited!  Write [email protected] for ordering info and credit card payment instructions.  Also here's our blurb from the ASL Group online store -
CAMBRE' Entre' entry-level 4 shelf audio system rack - Brand new in factory sealed carton (some assembly required) 9 inch high spacing perfect for everything up to the largest audio components. Wire management covers keep wires dressed nicely and power cords away from the interconnects. Easiest good-sounding rack on the market to assemble, takes a few minutes rather than a few hours to put together well. Anti-resonance technology makes all your equipment sound better and makes Cambre' a 'sound choice'! Overall dimensions 33 1/4 inches high by 23 wide (clears 18 1/2 inches between posts) by 19 1/4 deep . 300 lbs. maximum load, 75 pounds per shelf makes it perfect for all but the heaviest components.
rahimlee54
How much would the Entre or Timbre AV racks go for?  PM if you dont want to post site wide.
Jared
carabeeno
Hi Jared;
Thanks, the silver Entre' AV racks with 9 inch posts are $149 off from $460 list, and the same thing with 6 inch posts is $124.  Cambre' has told me that some people with really big screen sizes have purchased the 6 inch post model in order to keep viewing height optimum.  The 6 inch post height does not leave much space for any center speaker, it would probably have to be wall-mounted above the screen.  There is also a very small quantity of the black Entre' AV racks with 9 inch posts available at $199.
The Timbre' real wood veneer AV racks would be $339 off from $950 list, all those have 9 inch posts.  But, the finishes are limited, only rosewood, black ash, maple and cherry are available.  Quantities are also much more limited on all the Timbre' models.  Let me know of further interest and thanks again.
Parker King
Jared
carabeeno
One important note, the lead time on any order will be a bit longer than normal, most of the racks are in Canada, so that will add at least 4 or 5 days shipping/customs clearance time.
doug s.
  • makin' music
...Thanks, the silver Entre' AV racks with 9 inch posts are $149 off from $460 list...
...The Timbre' real wood veneer AV racks would be $339 off from $950 list...
hi,
does this mean delivered price of the entre av rack is $311 or $149?  and, the delivered price of the timbre real wood veneer av rack is $611 or $339?
thanks,
doug s.
carabeeno
Sorry for any confusion.  Delivered price of the Entre' AV rack with 9 inch posts is $149 to continental USA, and delivered price for the Timbre' AV racks with 9 inch posts is $339.
hi,
thanks,
doug s.
