0 Members and 1 Guest are viewing this topic. Read 4015 times.
For some reason I was thinking the person that swapped to the Radeon used a thread adapter.Again, I might be making things up again, so don't quote me.Bob
The crossover for the 15 PSI with Eminence compression driver and the 15 SSI with the Radian compression driver are way different from each other. Although it will do no harm to use the wrong crossover, it won't be even close to what it would sound like with the right crossover. Now, since there is no crossover being made for a PSI mid-woofer and Radian compression driver, neither crossover will be quite accurate, but the SSI crossover should be much closer to correct, as the two mid-woofers are similar in sound and specs (the SSI mid-woofer is a bit more efficient).Dave
