TLP Volume Potentiometer
0 Members and 1 Guest are viewing this topic. Read 1712 times.
T-Bone
« on: 17 Dec 2003, 02:26 pm »
Hi Hugh,
Your TLP schematic shows a 100K cermet pot while a 20K pot is offered as a option by Aspen. Are there outside limits to the potentiometer value? In other words could I use a 10K or 50K pot? Also if I wanted to utilize a balance pot should it be a linear taper and of what value?
Thanks again for your help on my previous thread.  :D
Brad
"Still Rockin' in the free world"
Malcolm Fear
« Reply #1 on: 17 Dec 2003, 07:16 pm »
I used a DACT 10k stepped in my TLP. Worked fine.
T-Bone
« Reply #2 on: 17 Dec 2003, 08:32 pm »
Hi Malcolm,
I appreciate your reply. The reason I ask is because a friend has ALPS 10K, 50K and 100K but no 20K.
Went back to the old forum and was scanning the posts there. It looks as though using a 10K or 50K pot would be fine. Hugh didn't care for the idea of using a 100K pot due a possible noise issue.
Brad
AKSA
« Reply #3 on: 17 Dec 2003, 09:24 pm »
Hi Brad,
Yes, exactly, and my apologies for the conflicting documentation;  I'll amend it right away.
I'm in favour of 10K through 50K.  No lower, and no higher.  In both the TLP and the GK-1 I don't to go below 20K because it's a fair load on the source;  many sources I've tried don't find a 10K load all that easy.  Generally the more expensive CD players will easily pull a 10K load, but a few baulk at it, and this is evident when you listen.
You often find the choice of value is determined by the marketplace.  For example, I couldn't buy the premium Panasonic motorized at less than 50K!!
Hugh
T-Bone
« Reply #4 on: 17 Dec 2003, 10:46 pm »
Hi Hugh, Malcolm,
Thank you for your input. Due to my mid-fi cd player I will go with the 50K pot. And Hugh I wasn't throwing stones at your assembly text. If you remember (and obviously I don't expect you to  :) ) my TLP kit was purchased way back on April 22, 02' so my assembly text was quite old. Besides I did not view the information as conflicting. I am certain many revisions have been made since. Your last statement contained the gold nugget I was digging for:
Thanks again and have a Merry Christmas! :xmas:
Brad
