Hooking up a pair of Open Baffle subs
0 Members and 1 Guest are viewing this topic. Read 2550 times.
zybar
« on: 27 Apr 2009, 05:38 pm »
Danny or Brian,
I am close to moving forward with building a pair of open baffle subs (with two SW-12-16FR drivers per sub) and was looking for some advice on how best to integrate them into my dedicated HT setup.
My room is very long (30'+ in length) and the subs will be located at one end of the room while the gear is literally at the other end.  Both subs would be connected to the LFE out of my Denon 3808CI receiver (via a "Y" cable), but I was wondering if I am better off having a very long single ended ic run from the receiver to the Servo amps (one amp per sub) or if I should have the Servo amps close to the receiver and have long speaker cable runs to the subs?
I am not sure if long speaker cable runs with the Servo amps create any issues or interact differently than a standard amp.
Thanks in advance for your assistance.
George
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
Re: Hooking up a pair of Open Baffle subs
« Reply #1 on: 27 Apr 2009, 06:00 pm »
Hi George,
Brian answered me here about max length of run from amp to sub
http://www.audiocircle.com/index.php?topic=47310.msg424901#msg424901
bottomline -basically up to 20'
-Tony
zybar
« Reply #2 on: 27 Apr 2009, 06:06 pm »
Thanks Tony.
Looks like my only choice is to have long, single ended ic runs.   :cry:
George
ebag4
« Reply #3 on: 27 Apr 2009, 06:24 pm »
Do these plate amplifiers only accept low level in?  I hope they accept high level as well
George, this is a bit OT, I will break off into another thread if need be.
Best,
Ed
keenween
« Reply #4 on: 27 Apr 2009, 07:17 pm »
maybe split the signal at one of the subs instead of off the receiver?
Danny Richie
« Reply #5 on: 27 Apr 2009, 07:28 pm »
You can use high level inputs or low level inputs.
If using high level inputs be sure to go up in wire gauge as length increases.
ebag4
« Reply #6 on: 27 Apr 2009, 07:32 pm »
Thanks Danny, good to know.
Best,
Ed
zybar
« Reply #7 on: 27 Apr 2009, 07:33 pm »
Danny,
Why is there a 20' speaker cable limit as per Brian?
George
Danny Richie
« Reply #8 on: 27 Apr 2009, 07:42 pm »
I believe that was from the sub amp to the drivers not from the source to the sub amp.
zybar
« Reply #9 on: 27 Apr 2009, 07:44 pm »
Ok.
So back to my original question...
Would I be better off with long single ended ic or speaker cable runs to the Servo amp from my receiver?
Thanks.
George
dvenardos
« Reply #10 on: 28 Apr 2009, 05:13 am »
30' isn't that long for a coax cable, why wouldn't you want to run RCA?
thomasjefferson
« Reply #11 on: 28 Apr 2009, 07:29 am »
Unless you've previously done an OB dual sub setup and you know how it's going to work (not likely, right) you have to expect some trial and error before you find the placement that works best in your space.  So you may want to use whatever cables you have and move the receiver close enough to reach, until you get it right.  Then you'll know how long of a cable you need.
The result of my OB project involved completely rearranging my furniture.
And I'd guess an RCA will work fine even for 30'.
TJ
Danny Richie
« Reply #12 on: 28 Apr 2009, 02:41 pm »
George,
Either way will work fine.
