Audio/Video Gear and Systems
Single Driver, Wide-Bandwidth Speakers
ejfud
Making holes and getting parts.
0 Members and 1 Guest are viewing this topic. Read 1789 times.
hobbyhands
26 Apr 2009, 04:07 pm »
What are you using to make your driver holes. Also right now I get my parts from partsexpress and madisound, and others you woul suggest?
jk@home
Re: Making holes and getting parts.
26 Apr 2009, 04:22 pm »
Router and jasper circle jig:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=365-250
If you have a local Woodcraft store, they carry them:
http://www.woodcraft.com/family.aspx?familyid=3582&ProductID=129955
Also Lowes sells something similar, but IMHO doesn't work as well.
hobbyhands
Reply #2 on:
26 Apr 2009, 04:52 pm »
I bought the lowes circle jig. I didn't even try it. After opening the box and looking at the instructions it did not seem to be the best unit to make speakers holes.
I'll look into the jasper jig. Looks like a nice product.
mike j
ยป
Reply #3 on:
28 Apr 2009, 10:43 pm »
I just bought a Jasper Jig and it's great. Great tool. No regrets at all!!!
ejfud
