wireless?
0 Members and 1 Guest are viewing this topic. Read 2183 times.
alexone
wireless?
« on: 26 Apr 2009, 06:55 am »
James,
what do you think about wireless (audio/video) data transfer? is Bryston going this route in the near future?
al.
  • The Demo is Everything!
    • http://www.bryston.com
Re: wireless?
« Reply #1 on: 26 Apr 2009, 11:30 am »
James,
al.
Hi Alex,
We have discussed it in our engineering meetings. The only issue that seems to be reappearing is whether 44.1/16 bit (which I believe is the fastest sample rate currently available at this point) is worth pursuing or wait till hi-res streaming becomes available.
Also with my new computer setups (2- windows systems and one MAC Pro) I have listened to a few Internet wireless radio stations and so far find them extremely variable in quality. I believe the maximum transfer rate there is 320 kbps and so far some soures tell me that should be as good as CD?
james
« Last Edit: 26 Apr 2009, 01:03 pm by James Tanner »
perose
Re: wireless?
« Reply #2 on: 28 Apr 2009, 01:19 am »
The Logitech Transporter - Decoders: WAV, AIFF, MP3, WMA, FLAC with 24-bit resolution, and 44.1, 48, and 96 kHz sample rates
The Linn Klimax DS - File types supported: FLAC, WAV. Audio sample rates: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176kHz, 192kHz. Word depths: 12–24 bits.
Also, I've seen that there are sites available that you can download hi-rez music from with Linn (up to 24bit 192KHz) being one of them.
I agree that if you're talking about Internet radio or CD quality then you don't need more than 16bit 44.1KHz but if your going to make a product that caters to the audiophile and is somewhat future proof then 24bit would seem to be the minimum.
Re: wireless?
« Reply #3 on: 28 Apr 2009, 03:45 pm »
Hi perose,
Thanks - so your saying the Lynn system will wirelessly 'stream' files up to 192/24?
I will have to look at that.
james
Moon Doggy
Re: wireless?
« Reply #4 on: 28 Apr 2009, 04:01 pm »
The Linn Klimax is $20,000 if I recall correctly. :icon_surprised:
perose
Re: wireless?
« Reply #5 on: 28 Apr 2009, 07:16 pm »
James,
I believe the Linn is wired only at this point and as Moon Doggy points out VERY expensive. The Transporter on the other hand is by all accounts a very good DAC with front end wireless technology that makes for a complete package.
