One last question ... Cornet
0 Members and 1 Guest are viewing this topic. Read 1475 times.
Laudanum
« on: 16 Dec 2003, 10:03 pm »
last one for now anyway.
I have some nice GP phono jacks on hand so I didn't order any from the parts list.  The ones I have give me the option of using the included insulating washers or not using them.  Should the jacks be connected directly to the chassis box for grounding or should I use the insulating washers?
hagtech
    • http://www.hagtech.com
« Reply #1 on: 17 Dec 2003, 03:39 am »
Depends where you put them.  Safer (against hum) if insulated and running PCB ground to grounding jack.
jh :)
