What tempature is your soldering iron set at
0 Members and 1 Guest are viewing this topic. Read 1684 times.
ecramer
« on: 25 Apr 2009, 06:13 pm »
I am curious where all you DIYers  have your irons set at. I am populating a small board for a CMOY headphone amp. My Hakko 929 set at 560. I was trained in the navy many years ago to solder and was qualified to micro minature work but at the time digital soldering irons were not around. I used to set the temp pretty much by eye and feel.
ED
JoshK
Re: What tempature is your soldering iron set at
« Reply #1 on: 25 Apr 2009, 07:08 pm »
I can't be of much help.  My soldering station is electronically regulated based on the type of tip you put in.  The fine point tips are usually lower heat than the wide fat tips.
jrebman
« Reply #2 on: 26 Apr 2009, 02:28 pm »
Ed,
What kind of solder are you using?
I use about 680 for most stuff using wonder solder, and maybe crank it up to 700 for larger pieces -- that's with the standard soldering iron though, and most of the time I use an American Beauty resistance soldering station which doesn't have a temperature setting, only a current setting.
The 680 degree setting is just right for perfect flow of the solder through plated through holes with the wonder solder, even on small transistors.
-- Jim
markC
« Reply #3 on: 26 Apr 2009, 02:39 pm »
I use good old Kester "44". For circuit board work and point to point, I set my station around 575. I'll crank it to 800 for heavy gauge wire to binding posts.
ecramer
« Reply #4 on: 26 Apr 2009, 03:03 pm »
Ed,
-- Jim
I have a Hakko 929 and a Hakko 939 Looks like my tempa a little low will move it up a little
ecramer
« Reply #5 on: 26 Apr 2009, 03:29 pm »
I have a spool Kester "44" I have been saving usually use wbt silver
ED
markC
