khartago amp question
0 Members and 1 Guest are viewing this topic. Read 1963 times.
lmosby1
« on: 23 Apr 2009, 12:53 pm »
I am thinking about getting a khartago stereo amp and wanted to know how much of a difference, (if any),in the performance of the amp if i didn't leave the amp powered 24/7. Thanks
CSI
Re: khartago amp question
« Reply #1 on: 23 Apr 2009, 08:30 pm »
Klaus will have the definitive answer but I can tell you I've used my Khartago both ways. Currently I work from my home with music on all day so my Khartago is never shut down. However I will soon be changing that and may go to the on/off scenario. In the past, I never heard anything bad when I shut it down (as when on vacation, etc.) but did notice that it seemed to need a half hour or so to return to "full song" after. (This is all after full break-in, of course).  FWIW, my elderly father-in-law (who pinches pennies) had my Khartago on loan for a few months and turned it on only when listening. He swore there was no difference at all.
Klaus?
UPDATE: This is from the Unified User's Manual available from the Odyssey website
http://www.odysseyaudio.com/
"Even after the initial break-in period, the internal components lose their charge each time the unit is
turned off. The full re-charging can take hours (and sometimes days!). Therefore, the best sonic
performance is achieved when the components are kept fully charged at all times. This essentially
means leaving your equipment on at all times--if you are comfortable with that arrangement. If not,
at least be aware that it will take some time for your unit to warm up and fully charge each time you
power up. These charged-based performance issues are applicable to most electronic equipment,
and are especially critical in high-end solid-state gear such as Odyssey amplifiers and
preamplifiers".
So there is the word from the man - and your options.
« Last Edit: 24 Apr 2009, 11:11 pm by CSI »
lmosby1
« Reply #2 on: 24 Apr 2009, 12:31 pm »
Thanks thats helps
hpc
« Reply #3 on: 24 Apr 2009, 02:19 pm »
I used to leave on the Stratos Extreme SE mono's on 24x7 along with the
Khartago SE monos.  After talking to Richard Gray (Richard Gray Power Company),
he recommends not leaving them on 24x7 as it tends to 'dry up the caps'.
I've taken Richard's advice and only power up when I need them, but usually, it's
power up; make certain everything looks/sounds okay; go do something for
20-30 minutes or so; then listen.  For the tube gear, I've been doing it this way since
buying my first tube amp; though, I used to leave the tube preamp on 24x7 as small
signal tubes last a long time and live longer by not power-cycling frequently.  But, you
really don't want to leave tube stuff unattended - things do happen and they'll
happen when you're aren't around.
Cheers!
klaus@odyssey
    • http://www.odysseyaudio.com
« Reply #4 on: 29 Apr 2009, 09:21 am »
Different systems,  different ears,  different behavior = different results.
I always leave all of my gear on ,  except for the Symphonic Line Erleuchtung.  With such a low consumption,  it is economically and ecologically ok.
